ok, i have a small question about TMPGEnc DVD Author. i have import all the movies i want into it, made a menu, and finished the output. so now, i have the DVD writing tool open, and it says size 1.7 Gbyte, now is that just the menu? if it is, where do i put the videos into, and what do i do if its too big? and if not, will the DVD still work if it has that much empty space?
If you've imported the movies into the tracks, created a menu and outputted to a DVD folder, then the 1.7 GB represents everything, videos and menus. And yes, you can burn 1.7GB as a DVD and it should work fine.
alright, well, something went wrong, because its already done, and it said something like burned 320 sectors out of 1800, or 18000 something sectors. and the disc doesn't work, i tried and tried and it doesn't work, i still have the DVD writing tool open, though, if there are any more suggestions. please help. thanks
What type of files did you import into TMPGEnc DVD Author? Were they mpg2 files?
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
