  1. Looking for a avs script for interlaced NTSC dvd encoding
    May 2001
    Well, what do you want to do? If you just want to encode the thing, then most interlaced parameters are set in the ENCODER (not the script).
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  3. O sorry dumb me. I wanna Deinterlace it
    Apr 2002
    Oskeeweewee Ontario
    Why deinterlace?? Is it for T.V. output?? If so, don't deinterlace...
  5. it has to be deinterlaced i need to know what to put in my avs
    Apr 2002
    Oskeeweewee Ontario
    Go to your AVISynth documentation, (AviSynth2\docs\index.html), and check out the Bob() function...
    Again, does it have to be deinterlaced?? You'll be losing a bit of quality
