  1. Guys i've looked on forum but surprisingly cant find a solution.
    I'm converting an avi with ac3 5 channel audio using vdub, and reencoding the avi with tmpgenc.
    I'm consistently getting the audio being 3-4 secs longer than the m2v file.
    I've checked the movies and its out of sync at the end of the movie rather than the start.
    I'm authoring with dvdlab, which i know has an audio tool for shifting the audio file, but this results in the whole audio being out of sync.
    I've followed baldricks guides on convertions so dont belive its settings
    Any suggestions would be of help.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    If the audio is longer cut the 3 seconds out (at a blank spot on the wav graph). There are pleny of wav editors out there.
    Kevin
