Okay.
Those of you who know me, know that I am constantly questing to be able to back up my DVDs to DVD-R using my E50. I've had spotty success, although ususally I have to put the show to tape first, then bring it back.
A few weeks ago, I thought I had solved the problem. I took a DC power supply and connected it to my Optex Video Stabilizer box. It's supposed to run on 9V, but found that it wouldn't do the trick unless the battery was almost brand new. Upon turning the power supply to 9.4V, I found that I could record almost anything from DVD-Tape-DVD-R, with no fudging around.
Then, just the other day, the picture got a bit jumpy, and the system failed!!![]()
I DON'T GET IT!
Can anyone explain why it would work for 3 weeks, but then not now? What could be causing this?
Is there any known hack yet for disabling that annoying blue screen on the E50, and making it disregard copy protection?
Thanks!
Mechworker
It probably took that long for it to fail from overvoltage. Remember that if a 9V battery measures 9.4 volts at the terminals, that's without any load applied. The internal impedance of any battery will limit the current and cause the voltage to drop when it's under load. Replacing it with a power supply (with virtually zero internal impedance) set to the open-circuit voltage is probably too much for it. It sounds like that's what you did to me. If not, never mindCan anyone explain why it would work for 3 weeks, but then not now? What could be causing this?
I thought of that. However, I usually turn the power supply down to 8.4V or so after getting the thing started.It probably took that long for it to fail from overvoltage. Remember that if a 9V battery measures 9.4 volts at the terminals, that's without any load applied. The internal impedance of any battery will limit the current and cause the voltage to drop when it's under load. Replacing it with a power supply (with virtually zero internal impedance) set to the open-circuit voltage is probably too much for it. It sounds like that's what you did to me. If not, never mind
Also, I did a test, trying to get the box to work to copy a heavily Macroe'd disk to tape, adn it wouldn't come without it, but did with it. (It cleared up picture bending, distortion.) Thus, I think the Optex is still okay.
Any other ideas?Mechworker
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
Copying DivX to HDD on a Panasonic DMR-EH57
By Ouchies in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2008, 07:05 -
F******n Vista! Arghhhhhh!
By Woddah in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 9th Jun 2008, 18:47 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 13:34 -
Pioneer 340 as replacement for Panny DMR-E80?
By LynnL in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jun 2007, 14:04
