I'm scanning in some photos for use in a vcd slide show/photo album. What resoultion should I scan them in at?
For NTSC, scan at any size higher than 704x480 (704x576 for PAL). However, you have to do an aspect conversion to make the pictures look correct. Normal 4:3 aspect ratios are 640x480, 800x600, 1280x960. When you want to burn them onto a VCD, you should convert them to 704x480. This is not a simple resize, but also a change in aspect ratio. The picture will look stretch horizontally on the PC, but will be shown correctly on the TV monitor.
So, capture any 4:3 image size and convert the image to 704x480.
Thanks, and this may sound stupid, but whats the best/easyest way to do that?
Photo Slide Show in AVCHD
By chrisnewton in forum Authoring (Blu-ray)Replies: 8Last Post: 23rd Apr 2011, 03:40 -
Making an interesting start to a slide show
By avz10 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2010, 23:57 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 07:27 -
best Super settings for slide show playback
By alldigitalsupport in forum Video Streaming DownloadingReplies: 0Last Post: 23rd Apr 2008, 12:21 -
Adding slide show to a movied DVD
By leungf in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 08:55
