I have a problem with some MPEG streams I feed to DVDLab. All my assets are prepared with Mainconcept using the same template. I encode to separate audio and video streams with audio MPEG 192kbps.
Practically, half the audio streams cause problems with DVDLab. It doesn't explicitly reject them, but it will either crash during compilation or compilation will succeed but the video will playback in "slow motion" with audio in normal speed, audio will run out and video will continue silent at normal speed.
Needless to say the streams are perfectly valid and Scenarist accepts them without any complaint and compiles perfectly playable DVDs.
Has anyone seen this behaviour?
The more I learn, the more I come to realize how little it is I know.
I too had problems with DVD-Lab and mpeg audio. It would import and compile OK but it wouldn't play OK. Other authoring tools had no problems with the same audio streams. I couldn't figure out why (probably a bug with DVD-Lab) but I found a workaround:
Import the mpeg audio at 44.1kHz. It will complain (obviously) and offer you to convert to 48kHz with its own audio transcoding tool. These worked OK each time.
Slight quality loss if your original was already at 48kHz though. -
Sounds like the workaround I found myself. I now got an even worse case where the DVDLab transcoder won't even transcode the file. Thankfully, it was able to convert it to WAV which I then re-encoded separatelly with MainConcept. The new MPEG audio file was properly accepted and compiled without any problems.Originally Posted by petar
Likely to be a bug in the s/w. Let's hope it will be fixed in the final release.The more I learn, the more I come to realize how little it is I know.
How to create an Audio-Only DVD in DVDLab Pro (IMPROVED)
By GordRocks in forum User guidesReplies: 26Last Post: 15th Jun 2023, 07:55 -
Ridiculous problem with Youtube (rejected video)
By stranno in forum Video Streaming DownloadingReplies: 3Last Post: 27th Oct 2008, 01:04 -
DVDLab Audio Playback
By alhall in forum Authoring (DVD)Replies: 1Last Post: 26th May 2008, 10:00 -
discontinuity in DVDAuthorGUI / rejected streams in Muxman?
By ecc in forum Authoring (DVD)Replies: 6Last Post: 12th Oct 2007, 00:18 -
HELP!!! video being rejected by youtube after i compressed it!!!!
By sharmine in forum Newbie / General discussionsReplies: 11Last Post: 19th Sep 2007, 14:59
