  1. DVD I backed-up has scracthes on back. As a matter of fact it is one scratch that prevents it from playing properly at a certain point. IOs there anything out there that can fix my scratch problem, other than backing the dvd up again? Thanks in advance for all responses.
  2. Member Treebeard's Avatar
    Aug 2002
    You could get a disc dr. it wil just buff the disc and remove a thin layer. or you could fill the crack w/ toothpaste. If its that valuable I would make a backup of it before it becomes unreadable though.
