    May 2002
    Manchester UK
    I am having problems with PowerDVD 4 and with Windows Media Player. With DVDs and wmv files I get sound but no picture. The PowerDVD does produce a picture but it is obscured by rectangles of frozen screen.
    Medion Power Cinema works OK. Weird or what?
    carpe diem maņana
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I guess you have codec problems. If your dvds will play in one player but not another somethings not talking with the codecs properly (a guess only).
    You could reinstall powerdvd and see if that clears it up. Or try a update from powerdvds website. Also windows media player only plays dvds if you have the proper plugin installed (ie you paid for the download).
    Good luck. Keep trying different things untill it works. But if you got one player to work stick with it.
    Kevin
    May 2002
    Manchester UK
    I have reinstalled PowerDVD but no joy. I suspect it is a codec problem. Does anyone know how to sort it out?
    carpe diem maņana
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I don't think that is quite true - I have not paid a cent for any plugins and my DVDs play fine in WMP9.
    You have already tried reinstalling PowerDVD. Try reinstalling Windows Media Player. If this fails then perhaps you need to look at the mother of all codec fixes - a clean install of windows.
    If in doubt, Google it.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    jimmalenko - I thought only the "true" dvd plugin worked. I guess I didn't go to the right download page Anyway, I use powerdvd and I don't have problems with it so I'm not worried. I hope he gets his problem fixed.
    Your right, a clean install of windows is the last resort to fix problems
    Kevin
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    cool. Just didn't want to send him on a wild goose chase
    When in doubt, reboot.
    As a very last resort, reformat.
