Gday,
I'n in Aus, using an AVerMedia card. I can record SD fine, and play it back in Windows MP fine.
But when I edit using Adobe Premiere 7.0 (Pro) the audio and video gets out of sync.
I think I need something to re-encode the mpeg. Any tips?
UPDATE:
I now use a program called VideoReDo http://www.drdsystems.com/VideoReDo/index.htm to free my files from any glitches, and to edit to the start and finish frames.
I then use Premiere Pro, with a plugin from MainConcept http://www.mainconcept.com/mpeg_pro.shtml
One of the reasons I was getting errors was because:
"Although Premiere Pro will import MPEG-1 and MPEG-2 material, it does not offer native MPEG editing or smart MPEG rendering. This means that MPEG data needs to be converted to another format (such as DV) for editing, and each frame must be re-rendered even if no changes have been made. And if your target format is MPEG, you'll need to convert your finished project back to MPEG.
The MainConcept MPEG Pro plug-in eliminates these limitations and turns MPEG-1 and MPEG-2 editing into a productive, high-quality workflow."
Hope this helps someone!
Digital Hi-8 only plays in recorder that it was recorded it??
By whit0214 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Jul 2011, 18:02 -
Editing video recorded with two cameras
By MI6 in forum EditingReplies: 3Last Post: 18th Feb 2011, 20:09 -
Video recorded with a Digital Photo improvement of the picture
By shorto in forum Video ConversionReplies: 8Last Post: 10th Jun 2010, 11:31 -
DVP5990 Won't play AVIs recorded from digital camera...
By stedyone in forum Software PlayingReplies: 11Last Post: 18th Oct 2008, 01:28 -
Editing recorded sounds from the Internet
By fLYtRap in forum ComputerReplies: 5Last Post: 17th Jul 2007, 22:54
