Just a question, must we always author a dvd just to view the movie within? I mean can we skip the menus, chapters and stuff?
Reason here is I have a divx movie and I want to convert it to dvd. All I want is to view it on the tv with good dvd quality and stuff. I don't really need the menus and stuff. So, is it possible to just transfer a mpeg-2 video onto a dvd, burn it and just view it?
I've found that creating a dvd is more complicated than vcd... With vcd usually Nero would just burn a vcd for me with a single click of the button. But it seems that when I want to burn a dvd I need to create some dvd files first and then put it into the videoTS folder???![]()
Much work indeed....because like I said, all I wanted was to view the movie in mpeg-2 format...
Anyway, my question is, any program that could just convert the movie into the dvd files so that I can drag them into the video folder and thus, burning the dvd? what program do you guys recommend? I have Nero Vision Express...but there's no guide here on how to use it? Thanks all. I've also heard of DVD-Lab? Good?
The difference between VCD and DVD that you are experiencing is the authoring stage - Nero does it for you with VCD-compliant MPEGs. You need to manually author your MPEG-2 file (authoring simply creates your IFOs, BUPs and VOBs). You can author so that the main feature plays on startup without any menus or anything.
If in doubt, Google it. -
One question guys, i need to convert my divx into a dvd, and I need to choose either ntsc or pal.... but my frame is 23. So what category does that fall into??? ntsc is 29 and pal is 25...?
Hello,
What type of tv system do you use? Professional discs (ones you buy) will say ntsc or pal. If you buy pal convert to pal.
I'm guessing the frame rate's 23.976fps ?Originally Posted by Immortal25
If so, this is an NTSC FILM stream. You need to convert to NTSC 23.976fps, but specify a "3:2 pulldown on playback" when converting to MPEG-2, which means that it will fool the player into thinking it is a 29.97fps NTSC stream.If in doubt, Google it.
Converting and Burning DVDs
By OtosReborn in forum Portable VideoReplies: 13Last Post: 6th Apr 2010, 21:59 -
Problem with Burning DVDs
By The Monkees in forum MacReplies: 2Last Post: 25th Oct 2009, 02:00 -
help burning dvds
By bunty90 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 13:53 -
burning dvds
By terrie29 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2007, 19:08 -
Burning HD DVDs...Help!
By Anonymous55 in forum Authoring (DVD)Replies: 6Last Post: 14th Jun 2007, 21:37
