Hi,
Theirs a glitch in the movie where the video messes up for a 2 secs or less and after that all the audio doesnt match up with the people speaking. Its delayed about 1 or 2 secs. Before I convert the video (avi) to SVCD it plays fine before and after the glitch. If anyone has any ideas on how to fix this, Id appreciate it.
Thanks.
Sound like you have a few bad frames in your avi. Use vdub to find and remove the bad frames and reencode.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I used Vdub mp3 guide to take out the bad frames and when it got almost to the end of checking for the bad frames I keep getting an error that says the program had failure and then I click OK and it closes. Anyone know what happened or what to do?
Originally Posted by LivingProof
If that fails you have, as I have detailed before, a corrupt download from a crappy p2p system. Throw it in your trash bin and either use a decent p2p system or buy the DVD if its available.
Matching up video & audio.
By Tybo727 in forum EditingReplies: 8Last Post: 2nd Mar 2012, 02:57 -
Matching Audio Qualities?
By Tchail in forum RestorationReplies: 5Last Post: 22nd Sep 2010, 20:48 -
Audio not matching with video
By jh1017 in forum Video ConversionReplies: 24Last Post: 13th Aug 2007, 22:00 -
Mac OS X: matching audio with video in iMovie
By Jeikobu in forum MacReplies: 3Last Post: 22nd May 2007, 10:48 -
Audio not matching video
By doby48 in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2007, 09:53
