I use DVD Decrypter and DVD Shrink. I also use nero burning rom. I am making backup copies of my DVD TV series. What I want to know is if there is a DVD authoring software that will allow me to make a menu for the episodes. I don't care about motion menus or anything like that. I just want a menu to pick which episode to watch without having to just skip though one episode to get to the second. Nero Vision Express will let you make menus if you are making your own DVD from avi's or other non-DVD video files, but won't work with DVD files ripped with DVD Decrypter and done with DVD Shrink. I won't allow any compression so I only get 2 episodes per disc, but would like a menu. Anyone know how this can be done?
TMPGEnc DVD Author maybe.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by Askar
http://www.nero.com/us/631956523192996.html -
You could try DVDAuthorGUI. It's free and should suffice for what you describe. It can take VOBs as you want to (as well as separate streams).
Another tool that takes VOBs is DVDlab (which is not free but it is cheap for its capability).
Hope this helps.It wasn't me. -
Ulead DVD Moviefactory
Haven't tried this method but I reckon it should work for you -
1. When you rip with Decrypter rip as ONE big .VOB file (you can set this in the preferences somewhere).
2. Load the .VOB into Moviefactory (or any other Authoring program that accepts .VOBs). I think it works in Nero also.
3. Then trim the imported VOB - leaving just Episode 1 - save the trimmed vob as "Episode 1" or whatever name you want.
4. Repeat step 4 for Episodes 2,3,4....etc.
5. Create your menu !
Hope this works,
Moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
help required on making simple but 'deep' dvd menus
By lancealittle in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2010, 06:34 -
A program for JUST making custom DVD video menus?
By gom in forum EditingReplies: 6Last Post: 23rd Oct 2009, 04:05 -
Making one DVD from 2 DVDs
By asadfx in forum Newbie / General discussionsReplies: 3Last Post: 15th Dec 2007, 19:51 -
How do you make menus for dvds....
By mmmipa in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 12:33 -
A little help making anime dvds please?
By t_jay17 in forum Authoring (DVD)Replies: 8Last Post: 10th Jun 2007, 21:16
