Theres just a couple things I can't seem to figure out in Vegas 5.0.
First, how do I take just one still frame from a video?
For example, in Premiere I could have a clip of a video, go to File>Export>Frame (or something like that) and I would get a .bmp of just that one fram that was in the preview window.
Is there a way to do this in Vegas?
Second, how do I blur things out, such as faces or license plates or something?
for blurring out license plates, check here:
Tutorial.
as for still frames, I'd just use Virtualdub, under Video -> Export Source Frame To Clipboard, then paste in a graphics program or whereever you need it.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
to grab a still frame, open the preview window (if you don't have it open) and click on the diskette or clipboard icon...hidden trick - the size and quality of the preview will be what you get in your frame..so set preview to full/best and float/resize the window so that the preview is full size before you take your frame (the preview size is shown at the bottom - make sure it matches your source)
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
sure. I've got a 97 civic, but I bet yours is customized.Originally Posted by 95civicex"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
kind of. not in the looks department, but more in the speed department.
engine swap, turbo. -
that was my bet..anyway good luck w/ your project..!
Seeing I Frames with Sony Vegas Platinum?
By HoosierGuy in forum EditingReplies: 3Last Post: 17th Mar 2011, 17:32 -
How Increase Density of Frames Displayed? Vegas 9
By solarblast in forum EditingReplies: 2Last Post: 14th Sep 2010, 11:37 -
Vegas is rendering frames it shouldn't
By tripecac in forum EditingReplies: 9Last Post: 16th Jul 2008, 12:26 -
Searching specific frames in VEGAS timeline
By schematic2 in forum EditingReplies: 5Last Post: 21st Apr 2008, 06:52 -
Blurring background in Sony Vegas Pro 8
By mashimiriam in forum EditingReplies: 5Last Post: 19th Apr 2008, 10:35
