I downloaded some old cartoons. The quality is great- aprx 100mb per avi episode.
I want to encode them with TMPGEnc to DVD. I want excellent quality. So I figured before resorting to trial and error I would ask for suggestions. I've never encoded a cartoon before
What bitrate shopuld I use? Any suggestions (or templates) would be appreciated. Time is not a factor- I just want high quality video.
How many minutes per episode and what resolution are they? How many do you want on a disk?
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks for the reply.
Each episode is aprx 21 minutes. The eps are 384 x 286. I do a lot of sitcom recording on my HS-2 and I always put 5 episodes per disc- SP quality.
I was thinking about putting 6 episodes on each single layer DVD. -
Originally Posted by dafoe
For the lower res 1600 kbps video bitrate should be good which would give about 5 1/2 hours on a DVD. Select the the low res template.
For 1/2 DVD res you could us 3,000 kbps which would give you a little over 3 hours on a disk. Select the full resolution DVD template. To change the resolution right click on "size" next to the greyed out resolution box and select unlock, then adjust the resolution.
Encode using CBR, high quality motion search and you should be good."Art is making something out of nothing and selling it." - Frank Zappa
Software or settings suggestions for screen recording
By Cassel in forum Newbie / General discussionsReplies: 11Last Post: 28th Sep 2009, 18:21 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
xvid4psp, encoding settings suggestions please, blu-ray-> blu-ray
By runLoganrun in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 08:07 -
Tmpgenc problems with divx avi's, encoder suggestions?
By kitykat_2004 in forum Video ConversionReplies: 1Last Post: 26th May 2008, 01:35 -
GL2 manual settings suggestions please.
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 4th Oct 2007, 00:28
