  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi All,
    This is no feature for adding subtitle in DVDit. Can I use Subtitle Workshop to add the subtitle after I author the DVD movies with DVDit ?
    Thanks.
    no. I would use an authoring with subtitle support like dvd-lab pro, ulead dvd workshop, dvdauthorgui.
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    Thanks Baldrick. Your reply really saves me a lot of time trying to figure how to add subtile with DVDit.
    but doesn't latest dvdit 5 has subtitle support?
    edit:
    no it didn't support it. confused it with latest ulead dvd workshop.
