Hi,
I hope someone could help me with this.
I a looking for a cd-r writer that can or have the capacity to burn 800mb/90min cd.
I need to know is brand and recording speed and how much is it.
Thanks,
Dvd knight
No problem I have 2
HP9150 8x4x32 walmart $70
make sure it is model 9100b version inside 9100c will not work.
HP9500 12x10x32 walmart $75
I have used over 100, 99min. CompUSA CD-R's from anywhere from 88min. to 98min. 45 seconds burned VCD or SVCD's without a problem.
WARNING!!! TO OVERBURN
HP9100b use only NERO 5.528 or 5.535
HP9500 use NERO 5.551, it will give you a error message that "this CD-R does not have enough space", just wait it will go away in about 10-15 seconds, then it will ask you you do you want to overburn your CD-R. Click overburn and it will go ahead and finish burning your CD-R.
What's the latest on VHS capture?
By loninappleton in forum Capturing and VCRReplies: 16Last Post: 17th Oct 2010, 23:00 -
Play from latest point
By spliffenheimer in forum Newbie / General discussionsReplies: 0Last Post: 10th Aug 2010, 12:54 -
what is the latest version for quicktime ???
By khalid81 in forum Software PlayingReplies: 2Last Post: 10th Jun 2009, 18:40 -
Latest Version of VLC
By Wanderlustus in forum Software PlayingReplies: 6Last Post: 20th Feb 2009, 13:47
