How low can you set the bitrate on a svcd before the picture gets noticably blocky? What is the best svcd bitrate setting for VBR? If I were to put exactly 50 mins onto a svcd would it look good or bad? What do most people consider the sweetspot for svcd 20 mins, 40mins, 50 mins?
-Jay
If the bitrate drops below 2200 then I switch to 2-pass VBR, and I'll go as low as 1800 avg. or so. In order to get more on a disk I'll use 352x480 resolution and go down as low as 1500 avg.
For VBR minimum I use 200, I've had problems on playback if the bitrate gets lower. For max I use 2400 as TMPGEnc will exceed the maximum anyway, and that causes problems too.
50 minutes puts the bitrate about 1900."Art is making something out of nothing and selling it." - Frank Zappa
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Converting Dvds, Settings with bitrate
By Ekeus in forum Video ConversionReplies: 24Last Post: 22nd Mar 2010, 19:19 -
DV AVI -> H 264 (bitrate and other settings)
By xprezons in forum DVD RippingReplies: 13Last Post: 31st Aug 2009, 03:13 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Video Bitrate Settings
By bdr13278 in forum Authoring (DVD)Replies: 2Last Post: 4th Nov 2008, 13:34
