Hi,
I finally got a dazzle and once install I was able to capture right away. but there are some problem here let me give you guys a briefing as to what I need and what I done.
I have been able to do:
capturing from cable and laser disc. I have no frame drop and the quality is the same as those from the original source.
I need help with this:
capturing from beta and vhs I have the sound in constant running but I get frame drop (or sudden freeze).
is there any solution to my problem cause I have lots of vhs that are needed to convert to cd-r either in vcd format or dvd format.
any help would be truly appreciated.
dvd knight
forgot to mention that I am using P4 1.7 mhz with 256mb rdram, geoforce 2 64mb and with a 40 gig harddisk.
having same problem... anyone know how to solve it???
I'm trying to capture from a tape that is 6hrs long (SLP) -
I am no longer using the Dazzle DVC-II since purchasing an ATI AIW Radeon (I needed a tuner), however I did experience the same problems you are referring to. I never did find a solution. I noticed that I could record from live TV (from the AV output of my VCR) without problems, but not from a tape without experiencing a lot of problems. I even went so far as to take my Dazzle over to a friend's house and try it there with my tape and Dazzle using his computer and VCR. No luck.
I think that you are stuck until Dazzle fixes the problem.
You might try to post your question at:
http://stop.at/dazzle2
This site is devoted to nothing but the Dazzle capture boards (mostly DVC-II).
If you do find a solution, post it as a reply to this thread so that anyone coming after you will find the solution when searching the forums.
I,ve been running a DVCII for about a year problem free
i use moviestar 4.21, always capture @ dvd 800kbits/sec & i use TWNH when i need timers
i disable preview when recording
never droped a frame, can record from any source
use svhs, PIII750, 768mb ram, & WinME
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
Dazzle Video Creator Plus Help Please!
By FragpooL in forum Capturing and VCRReplies: 1Last Post: 24th Jun 2011, 00:51 -
Dazzle Vid Creator Plus, or TV tuner card?
By cwb in forum Capturing and VCRReplies: 3Last Post: 21st Jul 2009, 09:38 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
Dazzle dvd recorder capture card and a VCR problem
By leeh in forum Capturing and VCRReplies: 5Last Post: 3rd Jul 2008, 14:53
