I have a problem with DVD2one and Barbershop 2. I am only able to get a working version of the movie with Disk copy. If I copy it with "movie only" it copies everything but when it is played it playes the first scene over and over again. Does anybody have any ideas what is going on?
I used MTR also. It backed it up fine. When I run it through DVD2One "movie only" the movie plays to about where Cedric "the entertainer" is running from the cops and bumps into Uncle Sam and then just repeats that scene over and over like a skipping record.
I copied it in "full disc" with no skipping problems. I would like to know why I'm having this problem ... so I do not run into this problem again (I usually only copy the in "Movie Only" mode. Thanks for your help. -
hmmm..
I too did a full copy, haven't tried in movie mode.
Try taking your full copy copy,
copying it to the hard drive,
and re-processing it
using DVD2OneX to get
a movie only copy.
at least this way, you
will be sure it isn't an
issue with your original,
as your copy should be
de-macrovisioned, de-css'd,
etc.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 11:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 11:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 07:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 17:11
