-i need help with converting .MOV to .MPG and vice versa
-thanks in advance
Simplest way is to use Quicktime Pro which allows you to export .MOV files as .AVI with a choice or parameters. This is the best way I have found and produces great results.
You can also use Adobe Premier and create a project, open the .MOV file and move it to the timeline. Then export in your choice or format. I have had trouble in the past with this method. Be very careful of audio and colours as I have had poor results sometimes. -
now, if you use quicktime pro to export it as an avi file, will it have sound? I am trying to convert the new star wars trailer but I keep having problems! NO SOUND! and Yes I know some mov. files are protected
I have converted many *.MOV files using Quicktime Pro and always got sound. The problems with the Star Wars trailer must be related to copy protection.
dvd to vhs recorders and vice versa
By videohell in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Nov 2011, 06:02 -
720p video on a 1080p TV, and vice versa?
By sldvd in forum Newbie / General discussionsReplies: 15Last Post: 16th Jun 2011, 21:21 -
How to convert 5.1 to 2.0 AC3 and vice versa
By lapetite_66 in forum AudioReplies: 5Last Post: 8th Mar 2010, 19:30 -
How to convert fullscreen to widescreen and vice versa?
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 16th Jul 2009, 23:01 -
change avi from 16:9 to 4:3 and vice versa
By slowjoe in forum EditingReplies: 9Last Post: 6th Jun 2007, 07:11
