why is the audio fine when i play movie on my comp but then out of synch when i burn it to cd-r with nero?
what format are you burning to the cd-r? vcd, svcd or divx/xvid? and also, whats the source, and whats the audio format?
my dvd player only plays VCD so i burn VCD. The movie is SVCD though. What do you mean by source and audio format? how do i get that info?
heres the info using avicodec...
File : 747 MB (0.0 B), duration: 0:00:00, type: MPG, 1 audio stream(s), quality: 80 %
Video : 0.0 B, 2200 Kbps, 25.0 fps, 480*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 0.0 B, 224 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported -
How do you make your vcd from the svcd source?Originally Posted by imtheking
Is the mpeg that you create in sync before you burn it to disk?
Does the vcd play in sync on your computer?"Art is making something out of nothing and selling it." - Frank Zappa -
1. nero encodes movie when i burn svcd as vcd
2. how do i find out if mpeg is in sync?
3. yes, movie plays in sync on my computer as svcd..but once i burn the svcd as vcd to cd-r and try to play on dvd player or my comp..it is out of sync....
by the way, i tried using tmpcodec or whatever its called and it wouldnt open..even after troubleshooting and making changes in settings....
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
