I just purchased Premiere 6.5 a few days ago so I have been reading up on it, I haven't found what I'm doing wrong here. The only way I can see my opacity rubberband is if I have it on the Video 2, or higher, line of the timeline. But when I put my video on Video 2, I can't get my transitions to drop to the timeline. Seems like it has to be on Video 1. Also, I didn't think it mattered, but my transitions will only stay on the timeline if I'm in A/B editing mode. If I'm on single track mode it won't stay. If I drag a transition over to the timeline and unclick, then nothing happens, unless I switch to A/B editing mode. Any help would be appreciated.
Ok, I've found a work around, but I would like to ask if this is how others do it. I recorded a 20min clip from my Digital 8 sony camcorder as an avi file. I dropped that clip into my project in 6.5. I added that clip to my timeline. To make transitions work, the clips have to be on 1a and 1b, but when they are on 1a or b, you can bring up the opacity rubberband. So, whenever I need to do a transition, I cut a segment of video and drop it down to 1a and b, then when I need to adjust opacity, the razor again and move back up to the video 2 line. I end up with lots of small clips on different video lines. Is this normally how its done?
My 2 problems with Adobe Premiere
By IT learner in forum EditingReplies: 2Last Post: 16th Sep 2011, 08:46 -
transitions hard to add on multiple clips in premiere
By codemaster in forum EditingReplies: 11Last Post: 7th Jan 2011, 11:34 -
[solved]Problems about transitions in DLP
By ihmcjacky in forum Authoring (DVD)Replies: 5Last Post: 2nd Feb 2009, 23:07 -
Picture opacity in Vegas
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2008, 22:26 -
Playback problems in Premiere
By JustinBaker in forum EditingReplies: 4Last Post: 7th Nov 2007, 10:41
