Is there any way I can tell if my audio is going to be out of sync with my video before burning? I did this:
-Extrated an AVI's audio to WAV using VirtualDub-MPEG2
-Used the WAV audio and AVI video in TMPGEnc Plus to create the .m2v and .mpa
-Authored using DVDlab. (Note: When I put the .m2v in the project assets it showed up as being 01:37:42, while the .mpa showed up as being 01:37:48.)
-Burned using Nero Burning ROM at X2.5
Thanks for any help.![]()
I check mine with virtualdub before I save off the wav. I just go to a point near the start, middle, and end and eyeball it. Perfect? no. Effective? Yes. I havn't had any problems doing it like that.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
How to sync video with audio
By Denster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2010, 22:25 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 13:30
