Hey! For burning one’s backup macrovision DVD discs
1) Do you know in practice which free software is better, the Decrypter or Shrink?
2) Must the Nero 6 be installed in order to use either the Decrypter or Shrink and why? Thanks.
Results 1 to 9 of 9
Hello,
You're mixing the two up a little. Dvd Decrypter JUST copies the dvd to the harddrive. That's fine if its a single layer but if you have a dual layer burner you need to compress dual layer dvds.
DVD Shrink decrypts AND shrinks the disc so it will fit to a single layer. If its already a single layer all it does is decrypt it to the hard drive like dvd decrypter.
I believe dvd decrypter burns on its own. You WILL need nero for dvdshrink to burn. Though, you should have a burning suite with your dvd burner.
i would say that the combination of dvd decrypter and dvd2one,is the best IMO.
and as far as im converned,Nero6 is shite for burning,so i use copytodvd.
never had a coaster that way,not interested with shrink or nero. -
I use a combination of DVD Drcrypter, DVD Shrink, and CopytoDVD.
Like Fox Breath, with shrink and copytodvd, never had a coaster yet.
LG -
I just use DVD Shrink and I haven't had any problems yet. But for DVD-5 back-ups I make an ISO with DVD Decrypter and then burn with DVD Decrypter. I haven't had a coaster yet. I have a Pioneer DVR-107D.
If all you're doing is ripping and then reburning a DVD-5, I daresay Decrypter is better. It's more developed at what it does - rip DVD's.
- Gurm -
Latest DVD Shrink version embedded former version of DVD decrypter. DVD Shrink is more intuitive to use but less capable of ripping DVD than current DVD Decrypter.
Sam Ontario -
Use them both. Choose in shrink to write with decrypter. When its ready, up comes decrypter ready to write.
Decrypter to Shrink to Imgburn?
By visionman in forum DVD RippingReplies: 3Last Post: 19th Jan 2011, 12:06 -
D v d Decrypter and shrink
By Leftbehind in forum Authoring (DVD)Replies: 3Last Post: 7th Oct 2009, 02:18 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
I can't rip with DVD Shrink or DVD Decrypter
By Baldrick in forum DVD RippingReplies: 77Last Post: 10th Feb 2008, 12:46 -
RipIt4Me, DVD Shrink, and DVD Decrypter on Vista?
By RowMan in forum DVD RippingReplies: 1Last Post: 24th Oct 2007, 22:45
