Results 1 to 10 of 10
  1. I am having problems playing my DVD's i get this message.
    http://www.reddeth.com/pics/dvd.jpg
    I reinstalled my Divx codec/ PowerDVD and nothin any clues?
  2. What is the content of the DVD's (conventional MPEGs or something else)
  3. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Found this in Google. Might be worth a try.....
    "Go to Start > Run and type in "dvdplay". If it doesn't work your Directshow Filters are screwed up. Try downloading the latest version of Directx. If that doesnt work your hosed and its time to reinstall the OS. Once the base layer of Dshow is corrupted you wont get DVD playback to work."
  4. Its just a normal DVD i bought in fact i can't play any DVD that i have.
    My DirectX version is 9.0c
  5. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    But have you tried reinstalling it?
  6. Originally Posted by tekkieman
    Learn something new every day...Thanks!
    Originally Posted by jagabo
  7. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    dvdplay just loaded wmplayer for me.....
  8. started this on my laptop
  9. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Wonder if it's a difference between XP and Win 2k. Just noticed the difference in your specs. Just found the reference in Google, and though it might be worth a try.
  10. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    yeah, i haver seen that app before, think it was when my box was 2k...
    another good reson to not "upgrade" to xp
