I want to copy kids movies i have on vhs to dvd, also analog home movies from my camcorder. my computer is a p3- 733 and can't afford to update all at once.
heard good things about 5005, if i make dvd from 5005 can i copy to computer and then edit my home movies and add music etc. also can i fit more than one kids movie on dvd. thanks i am a real rookie at this, with not a whole lot of money or time- whomever
If you want easy, then the DVD recorder is the way to go. You can get 1-2 hours on a DVD, more if it has a long play mode.
The problem is editing the resulting MPEG2 video on a computer. MPEG editing is more difficult to keep audio/video sync than AVI or DV. (DV is a type of AVI.)
Just something to consider. I use a ADVC-100 and the DV output can be edited, or processed with filters with simple tools such as Virtualdub. -
Definitely LiteOn LVW5005. If you need editing on the disc, you can try Philips DVDR75. I had it for 2 months now, very good too.
Sam Ontario -
No money and no time = no editing for you. Sorry, that stuff takes time, and the software and PC hardware takes money.
For easy tape to DVD conversions, DVD recorder is fine. The LiteOn gives great quality, useful MV hacks. The best recorder however is the JVC DRM10SL right now.Want my help? Ask here! (not via PM!)
latest posts on both liteon 5005 and advc-100 implies can no longer be updated to bypass macrovision. is this true? seems as though liteon 5005 manufactured june 5004 won't take hack.
does the advc-50 jumper trick still work for macrovion -
i heard about the hack tricks with some capture devices. I just bought the DAC-100 which is identical to the ADVC-100 but it is £60 / $100 cheaper than the ADVC plus it also removes the macro vision without the need for a hack trick. quality has been fantastic on what i have captured and i used this on a P3 700mhz packardbell laptop that has taken a serious beating over the past few years. so if your looking for a cheap alternative thats going to do the same if not be slighty better than the ADVC-100 get your self a DAC-100
What I've Learned so Far-LiteOn 5005
By RiteOn in forum DVD & Blu-ray RecordersReplies: 27Last Post: 14th Oct 2012, 21:58 -
Liteon 5005 dvd drive
By kenmo in forum DVD & Blu-ray RecordersReplies: 8Last Post: 15th Jun 2010, 15:58 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
Liteon LVW-5005 can’t prepare 16 X DVD-R before recording
By coody in forum DVD & Blu-ray RecordersReplies: 24Last Post: 8th Jun 2009, 15:54 -
LiteON 5005 weirdness
By kenmo in forum DVD & Blu-ray RecordersReplies: 53Last Post: 2nd Jun 2008, 12:05
