I have been reading LOTS about problems with recorded discs on this machine not playing in other DVD Players. I just bought one the other day and I'm considering exchanging it for the Toshiba D2. Anyone have any advice...as I'm not really sure what to do.
Thanks!
From what I've read from various sources prior to buying my E55 a lot of issues seems to be down to either the media or not properly finalising the discs first.
I suggest as you already have one just make a recording or 2 & try it in as many machines as you can before deciding.
Here in the UK the E55 has been described as the best machine you can buy for the money in one mag. And no real compatability issues have really been reported from what I recall in 2 weeks of research.
Tubol -
Try using better media, say Accus or if you're rich, Panasonics.
Change the record method from AUTO to Fixed if you want more compatiblity but mine play in anything I use & its set to AUTO.
Panasonic AG-1980 playback issues HELP
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 10th Feb 2012, 01:29 -
Panasonic Viera TX-P42UT30B - MKV Playback issues
By nathan1990 in forum DVB / IPTVReplies: 2Last Post: 20th Dec 2011, 05:25 -
Pixelation issues with Panasonic DMR-EZ28
By DaneClark in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Apr 2010, 14:27 -
Panasonic DMR-EZ27K DVD+R DL issues?
By ManuBumb in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Sep 2008, 15:00 -
Help! New Panasonic DMR-EH50S freezing and having issues!
By dvd-dude in forum DVD & Blu-ray RecordersReplies: 5Last Post: 11th Oct 2007, 11:09
