I have an 8x speed DVD writer hooked up to my iMac in an external Firewire case. When I go to burn at 8x speed the buffer underun protection kicks in constantly. The max speed I can get from the burner without the buffer underrun protection kicking in is 6x.
Is this the limit of the IDE hard drive and CPU?
Nope. Well, probably not. I assume its a 7200 RPM drive, but even if its not, it should be speedy enough to handle it. IDE is not a limiting factor in hard disks, as of yet, and I assume that even a 5400 drive would be able to keep an 8X burner fed.Originally Posted by Falcon500
Probably.Originally Posted by Falcon500
I would have thought that your computer would be strong enough to handle it, but I suppose that burning at 8X requires a fair amount of horsepower.
Check the process view the next time you burn a disk. If it keeps redlining, then your processor is at fault.If it isn't broken, take it apart and find out why.
blog: deadsierra -
It does have a 7200 rpm hard drive. I think the specs on the IDE bus are only 66Mbps instead of the newer 100 and 133 speeds of newer macs...
I just checked Activity Monitor and found Toast 6.05 to be the culprit. When I run Toast 6.03 I still have head room. Even when reading a DVD (to copy it) Toast seems to max out the processor in version 6.05. Has anyone else found Toast 6.05 to use more processing power than previous versions? If not perhaps I should download the latest version again to see if that helps..
600MHz is definitely enough for 8X speed. I''m using 450MHz G4 and for burning purposes (8x), 600MHz G3 has more horsepower than 450MHz G4, encoding MPEG2 is another story, because G3 lacks AltiVec.
You could try something other software, Discribe for example. It's easy to use and demo lets you burn five disks. If you want to buy it, it's cheap. Or Missing Media Burner, Firestarter, etc (free).
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
How to limit dvd burning speed
By zakman in forum Authoring (DVD)Replies: 6Last Post: 19th Sep 2009, 01:53 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 03:41 -
The best burning speed for the most compatibility with DVD players?
By gom in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:30 -
dvd burning speed
By nobbyiscool in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2007, 08:54
