Hi,
I have authored an svcd file into mpeg2 for burning to a dvd
used nero vision to add chapters etc etc. Never had any problems before.
Problem starts when i try to burn the disc it will get so far then just crash?
I have tried using Nero & Clone cd but it still crashes.
Is my burner gubbed or is it the file i made? When i restart the pc and eject the dvd it plays up until the point the program crashed.
Really annoying as this is the only time i have had problems.
Any help would be great.
RS
i'd never suggest authoring SVCD files to DVD, i would re-encode to DVD spec, either full D1 (720x480) or half D1(352x480).
DVD authoring software is less likely to crash when actually using DVD compliant files.... -
To paraphrase the little kid in "Kindergarten Cop" who said to Arnold Schwartzeneggar, "Maybe it's a tumor":
Maybe it's your media. -
Tried diff media.
Still happens also nero will not even do a dvd copy?
Freezes half way thru
RS -
what media -were- you using and what media -are- you using now? DVDinfopro will give you a media ID code.
Hi,
Yep more crashes tried to do a dvd copy and it crashed again.
Uninstalled Nero and reinstalled and it did not work. Took
Nero off and have installed Roxio to see if that works if not may have to
reinstall windows.
Any ideas?
RS
Problem with Philips DVDR-3505
By obolon84 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Jul 2010, 09:54 -
Magnavox NB500MG9 (walmart) BD player..Nero vision..BD on DVDR working?
By markm75 in forum Authoring (Blu-ray)Replies: 8Last Post: 1st Dec 2008, 02:11 -
Burning a DL dvdr problem
By efiste2 in forum DVD RippingReplies: 3Last Post: 16th Jul 2008, 15:06 -
Is This A Common Problem? DVDr to AVI
By innovyse in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 05:09 -
Problem with Philips DVDR 3460H
By sonybetamax in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Sep 2007, 14:59
