i use ulead dvd factory to convert divx's (and pretty sure i have done avi's) to dvd and burn and play on tv...now when i try it either a) imports them to story board and begins to burn/create iso takes about 5 hrs then fails or b)crashes whole program (encountered error)......driving me crazy, not keen on running thru complicated apps and taking 40 hours as one guy said?!?!?!
please help
warning: fbi will charge all piracy offenders with $250.000.
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
https://www.videohelp.com/forum/userguides/220351.php
Also TMPGEnc XPress can convert it to mpg then TMPGEnc DVD Author to DVDYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Iv'e been trying out TheFilmMachine, a freeware program that uses CCE or Procoder to encode. Decent quality and very easy to use. Works great for XVID video. Seems to work with MP3 VBR audio also.
Thanks, redwudz
I do not usually convert avi to dvd but I'm downloading that one right now as it looks promisingYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
i actually got it to work last night using ulead dvd factory3 , trick is not to create menus etc - just play straight to movie! took bout 2 hours and quality is great......
Vobs, making them easier to use.
By nickhopkins07 in forum Video ConversionReplies: 2Last Post: 14th Sep 2010, 15:45 -
Standalone DVD recorder - is there and easier way to ensure audio sync?
By dphirschler in forum Video ConversionReplies: 20Last Post: 30th Dec 2009, 02:57 -
Is it easier on the burner to use R or RW media?
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 25Last Post: 28th Nov 2008, 11:40 -
Subtitles: easier way to create them?
By tirengarfio in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2008, 23:43 -
DVD5 to Mini DVD, Which is the best and easier Software out there ?
By acidcrash in forum DVD RippingReplies: 12Last Post: 29th Aug 2007, 12:25
