FFMPEGX is great. With FFMPEGX0.9a, I'm frustrated that when I have a file that's 23.976 (NTSC Film) FPS, and I want to make sure the file is converted to 29.97, I can't seem to do that. The presets are for the original frame rate of the program. If i attempt to click on the FPS window, and I say NTSC 29.97, it won't work. The whole thing encodes, but I ended up with a m2v + mp2 that was different lengths when I drop into DVDSP (as .ac3 file). The m2v was much longer than the converted .ac3.
To do this, I actually have to go to a PC and do TMPGenc!
Oh, wait a minute. Is this the option "Undo 3:2 pulldown"? Will that encode the file BACK to 29.97fps? Thanks.
You're still using 0.9a? Isn't that like 12 versions out of date ...?
thank you. But, by default Set 3:2 is enabled under options and the resulting video (I AM going by memory here) is the same framerate as its input, in this case 23.97 NTSC Film.
What happens if I input an NTSC Film source and DESELECT Set 3:2?
My goal, of course, is to generate a result of NTSC 29.97 fps.
If I allow the video to remain at 23.97 fps, I can see the defects on the video. I can see the pixellation, etc. on walls and backgrounds. File size tends to be smaller as well. I need the best option of 29.97 for better quality encoding. And on DVD, I have the space for that.
...so there's no technique to resample at 29.97fps, which is what I want? (And yes, NTSC Film does play fine on the player, but as I mentioned, the slower FPS results in a video that's not as well encoded because I can see the pixellation and lower quality...)
At the moment, I'm annoyed that I can only do this on PC's TMPGenc Plus. Over there, I can tell it to take the 23.97fps and make it a 29.97fps video and the quality is quite good.
But figuring out the best bitrate, I have to use FFMPEGX's bitrate calculator...
Increasing fps in Staxrip encoding mkv files.
By Jayyflyy in forum Newbie / General discussionsReplies: 1Last Post: 10th Apr 2011, 14:05 -
FPS during encoding process
By godwentpunk in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2009, 12:43 -
Is 6 fps encoding for .ts file normal?
By burchis in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Apr 2009, 10:05 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
Encoding XVID from 10 FPS source
By dilly323 in forum DVD RippingReplies: 5Last Post: 15th Nov 2007, 00:00
