I was backing up games fine using Easy CD Creator 6 (create disc image) on a Windows XP machine but had to reinstall the operating system and all of the software. Now, I get the following message when trying to backup a game that is large. (>1GB) "Caching of files to your hard drive has failed. Please verify your layout."
Any ideas?
If there is a better place to post PS2 questions, please say so. I did a search and there were quite a few posts here. Unfortunately, the search didn't turn up anything for my caching error message.
Thanks.
Try DVD Decrypter in iso read mode,i would never use cheesy cd creator for anything.
Believe it or not DVD Decrypter works real well, I use it to back of all my PS2 games. Use mode/ISO/read then use DVD Decrypter mode/ISO/write and I always burn at the slowest possible speed I can 1x.
I tried Dvd Decrypter with the ISO read write and can't get my copies to work. I'm using the same brand of dvd media that I burn for my dvd movies and these work great in my PS2. I too would appreciate any help in solving this problem. Thanks in advance.
Wow that was fast; thanks for the quick replies guys! I just tried Decrypter and ISO read worked great; now I'll have to try the burn and see what happens.
Thanks again. -
i use decrypter as well but if that doesnt work u can try prassi primo dvd 2.0 or alcohol 120%
hp dvd 1040i, hp simple backup, error message:sbwin32.exe has generated err
By 84transam in forum DVD & Blu-ray WritersReplies: 4Last Post: 8th Jan 2008, 14:18 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 15:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 13:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 16:27
