I have several encoded episodes of the 70s show that are encoded in divX3 with nandub.
I want to convert them to mpeg but tmpeg and vdub say that there is no valid audio decompressor installed.
I have several divx3 codecs installed.
What can I use to extract this audio to wav?![]()
Results 1 to 9 of 9
You need to have the old divx hacked codec installed. Do a google for edskes file mirror and download the "K-Lite Codec Pack full" there. Chose a custom install then install ONLY the divx 3 stuff.
Check and see if the audio is ac3,if it is then you will need to install ac3 acm decompressor.
Alternatively you could use Cool Edit 2.X and choose "Extract Audio From Video" then save as WAV. Cool Edit lets you save as WAV any file you've got a DirectShow filter to read -- this assumes that you already used GSpot to identify the Divx filter you need and installed it so you can hear sound when you use Windows Media Player.
DivX is a video codec, not an audio codec. I'd suggest the Goldwave method.
/Mats
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 17:14 -
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 11:07 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 20:07 -
How to convert any video or audio to WAV using mplayer
By Baldrick in forum AudioReplies: 12Last Post: 15th Nov 2007, 02:08 -
Best program to convert Audio Cassette Tape to WAV
By jimcornetet in forum AudioReplies: 8Last Post: 14th May 2007, 16:48
