Do you need 2 drives to use DVD shrink 3.1 to shrink and burn a dvd. By that I mean do you need at least one dvdr/w drive and at least a second dvdr drive. I only have a dvdr/w and a second cdr/w drive however when I was using DVD Shrink 3.1. the destination where it was going to burn the cd was where I had the original dvd that I shrunk(dvd r/w drive) and as a result I could not complete the burning process cause it was going to burn over my original.
Help me please. Any ideas or sugggestions for me to solve this problem is appreciated. Thanks.
it cant burn over the original.when you get to that stage just eject the dvd and insert blank.
Originally Posted by ojtwelve
The original dvd gets ripped to and shrunk on your hard drive. You'd be burning from there, not from the original. Once Shrink does its work, you remove the original and insert a blank. The original is a pressed disc and wouldn't burn over even if you tried. My personal preference, however, is to use a separate reader (dvd-rom) since it rips faster than & leads to less wear & tear on my burner.
Like a flea circus at a dog show! -
If burning target is is .iso and you launch dvddecrypter to burn that you might encounter "this volume is locked" or something like that. In that case in the settings in dvddecrypter uncheck under the tab 'iso write mode' the 'lock volume for exclusive access' and voila problem solved.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
