Has anyone with the new version of TDA (1.5.26.73) used the DVD writing tool? For those who have, any problems thus far?
I haven't encountered any problems while burning; every disk has been basically flawless, so far. HOWEVER, when the disk is ejected after burning I get a dialog box that just says "writing". Weird because it's DONE WRITING when that box appears and then the program hangs when I click "OK". Possible bug?
I've never gotten good results from the tool. Some burns are good, others just make coasters. I save to a folder, then burn in Nero.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
I've had coasters from it, so I tend to not use it.
I've been using it because it's convenient and because I haven't had ANY bad burns.
I use Maxell DVD-R (MXLRG02/TYG021) media almost exclusively in my Pioneer A07. Checked each and every one of the last 50 plus disks and all have been perfect.
This appears to be a glitch in the s/w or my configuration (or something). The burns are still okay for me, though.
Tool for Editing MKV Without Re-Writing Entire File?
By Wardrop in forum Video ConversionReplies: 3Last Post: 14th Jul 2011, 07:17 -
FLVSplitter / FFDshow FLV resolution anomaly
By davexnet in forum Video ConversionReplies: 9Last Post: 16th Nov 2010, 00:22 -
Disc writing tool not working in TMPGEnc dvd authoring 4
By egor909 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2009, 06:14 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04 -
DL backup anomaly w/ ImgBurn2
By Seeker47 in forum Newbie / General discussionsReplies: 0Last Post: 16th Aug 2007, 15:33
