im trying to convert a divx movie to mpeg that windows says has a framerate of 20fps and tmpeg says has a framerate of 60fps. i have tried before using the usual vcd template that came with tmpeg which should change the framrate to 29.97 but it doesnt work at all after the conversion is done.
what settings should i choose and what should i do to make it work correctly?
oh and i also get the same thing when i try to convert a movie encoded with the SMR codec
<font size=-1>[ This Message was edited by: mduke on 2001-11-16 17:42:05 ]</font>
Results 1 to 1 of 1
60fps Conversion
By rivitingeffect in forum Video ConversionReplies: 34Last Post: 11th Jul 2013, 01:19 -
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 21:27 -
DVD to DivX Conversion - Recommended File Sizes
By DakotaThrice in forum Video ConversionReplies: 3Last Post: 13th Jun 2010, 07:31 -
Converting 720p/60fps file to 30fps?
By mt123 in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 12:34 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21
