    Jun 2004
    Is there anyway to TMPGEnc open and convert movies in MPEG 4 ?
    I have several movies I want to edit but it wont open them, andyone experience this problem?
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    Open them in virtualdubmod first, edit there, then frameserve to TMPGEnc, then reencode.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
    Jun 2004
    That worked very well using VirtualMod,
    Any way I can join two clips together, I didnt see it in the filters using VirtualMod?
    canada
    Load one file and then choose append segment and load the other file,both files must be the same though in bitrate and audio.
    Jun 2004
    Thank You very Much
