Hi, I've just tried to expot a .mov from quicktime pro 6.5, saving as an avi file. Unfortunatly the mov was a bit to big to do this and so my hd ran out of space, the problem know is that i cant find the exported file, which is using up about 40gig of hard drive space. Anybody know how I can find it and delete it or am I going to have to format my drive?
Any help would be greatly apreciated.
Lev
You don't say what OS you are using. Fill out your Computer profile, makes it a lot easier to answer.
Have you tried a search? Use advanced, video. Set the search for the last few days and you may locate it. Try a few different options if that doesn't work. Once you have located it, delete it.
Another method, look in 'Documents and Settings' on your boot drive, Owner, UserData. Check the folder sizes, will be large.
ripbot only converts half the movie
By AmDD in forum DVD RippingReplies: 8Last Post: 11th Feb 2012, 07:50 -
remove subtitles from half SBS movie
By sportflyer in forum SubtitleReplies: 2Last Post: 1st Jan 2012, 23:27 -
.flv only convert half of movie in iSkysoft...please help!
By evision in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2009, 11:20 -
MPLEX.exe only creates HALF the movie.
By supermannnnn in forum Video ConversionReplies: 5Last Post: 19th Aug 2007, 23:45 -
Converting QuickTime movie to Flash to reduce file size
By Vaugust in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2007, 14:28
