hi
i wish to know if there is a way to open ripped VOBs (VOBS in the hard drive) in DVD Decrypter so i can demux them?
thanks!
Increase knowledge, increase sorrow.
If you must use DVD Decrypter then you will need to make an image of your vobs, then use Daemon Tools and mount the image, then open in DVD Decrypter. Much easier to use ReJig in file mode.
thanks!!!
i tried VOBEdit and work fine..
but only with a few files..
i ask this because i work with scenarist, and sometimes i like to re-authoring dvds, to add my own menus and stuff or to make recopilations of the best parts of my concerts...
it works fine when i rip directly form the dvd, (demuxing) and the add the m2v and ac3 files to scenarist...
(works all the time with dvd Decrypter)
but when i have the files in my HD and i want to do the same (demux them to later import them in scenarist)
I use VOBeDit but when i import the ac3 or pcm files to scenarist i usually get
Error Invalid sampling Quantization.
Error Failed to import audio file.
dont know why
i'll try with daemon tools like steveryan said..
anyone know why i get this in scenarist?
or another way to use the files in my HD in DVD Decrypter
thanks a lot
-StKIncrease knowledge, increase sorrow. -
Originally Posted by stk
I try to demux a dvd but when i mux them again the video shows late
By sky-walker in forum Video ConversionReplies: 5Last Post: 25th Mar 2010, 13:11 -
How to demux a remuxed dvd ?
By WinSpecToR in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2009, 16:56 -
easiest way to demux audio from DVD then add it back in?
By fotty in forum Authoring (DVD)Replies: 4Last Post: 12th Jun 2008, 08:46 -
Demux DVD Video to separate M2V and AC3 files
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2007, 20:03 -
demux DVD Video to MPG!
By GangstaRap in forum Authoring (DVD)Replies: 10Last Post: 8th May 2007, 17:45
