Is this possible? I was wondering if there is a way to hook my laptop to my tv to record a movie? Is it really complicated and how do I go about doing it if it is possible? Any help appreciated! Thanks!
What do you want to do?
If you want to send the video from a laptop, you need a video output. Mine has SVHS out and I can send that to my TV, which has SVHS input. If I wanted to capture video from a video source, I would need a video capture card on my laptop.
Either way, you will need a video system on your computer or a PCMCIA card that can input/output video. Laptops have the further disadvantage of a generally slower processor and a smaller harddrive that makes video capture/output more difficult.
There are USB 2.0 external boxes that can make it easier. -
I'm assuming you want TV-out. Does your laptop have an svideo port? many do. then you can get a cheap svideo to RCA (red/yellow/white) standard AV hookup cable. If it doesn't have an S-Video port, then it probably has a standard VGA out, and there are VGA-to-TV adpaters but I don't think they're cheap.
Hooking up laptop to my DVD Player
By eggs44 in forum Newbie / General discussionsReplies: 11Last Post: 11th Oct 2010, 12:59 -
Problem hooking up my laptop to my new samsung tv via hdmi...
By theone4355 in forum Newbie / General discussionsReplies: 0Last Post: 21st Dec 2008, 23:47 -
Can any one explain hooking up laptop to lcd tv
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jan 2008, 21:15 -
Hooking a laptop to a dvd recorder
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 1Last Post: 21st Aug 2007, 14:46 -
Best choice for hooking up my laptop to my tv?
By Chems1919 in forum Newbie / General discussionsReplies: 12Last Post: 18th Jun 2007, 15:11
