I just did all the editing and encoding using tmpge and the file size was a little too big. I am trying to put multiple cartoon episodes on one dvd and was aiming for 6 which is about 2hrs and 10 of actual video. So with the mpeg2 file already made I dont want to redue the enitre process again at a lower bitrate(11hrs of encoding). Is there a way to shrink the file a little? If so, will this have a big effect on thw video quality? Or should I just encode again using a lower bitrate? thanks..I hope this makes sense.
Go ahead and author your title set like normal and use DVD Shrink to make it fit. If it isn't satisfactory quality, your only other option at that point is to re-encode the thing with the correct bitrate.
There's a bitrate calculator around here somewhere on this site, FWIW."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
What Is The Quickest/Easiest Way To Shrink MKV File
By Teac23 in forum Video ConversionReplies: 2Last Post: 19th Feb 2009, 04:56 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 05:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
