netime i try and finalize a disc no matter what is on it, it fails, does it HAVE to be panasonics own discs??
im using 2 cheap discs i got
No don't use cheap media. Use Accus or, hey, just like you said, Panasonics. Gotta test with the manf's media.
I have the Panny E60 and it has used any media that I threw at it. I buy mostly the 2X TDK that they put on sale. Slow for my Pioneer A05 but great for my standalone. There is no need to buy fast media. I have used the cheap CompUSA brand also with no problems.
i was using a mitsubishi dvd-r and a mirror dvd-r, both recorded onto the disc fine but they both failed when i tried to finalize, im trying to find the best place to get the panasonic ones
i tried a panasonic one there and it worked fine, can sumone tell the best and if possible cheapest ones to use in thw UK??
thanx for your help folks -
One way is to just use the dvd writer topic on the left column & search for the panny & youll find what media people are using.
problem with TV GUIDE on Panasonic DMR-E85H
By ktnwin in forum DVD & Blu-ray RecordersReplies: 10Last Post: 13th Feb 2013, 18:21 -
panasonic dmr e85h no audio/won't record
By janeydoll in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Mar 2011, 16:13 -
Panasonic DMR-E85H Digital Tuner
By scustalow in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Apr 2008, 14:01 -
Panasonic dmr-e85h recorder/writer player
By BIFFtheSTIFF in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Feb 2008, 22:33 -
Really Strange Panasonic DMR-E85H Problem
By dafoe in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Aug 2007, 09:04
