I've just captured a programme off my Skystar2 and want to burn it to DVD..I've done this many times before..grab it in MPEG2, edit (If necessary) it in Womble MPEG Wizard 2003 and author/burn in TMPGEnc DVd Author.
In this case, no editing was necessary, so I put the MPEG straight intoTMPGEnc DVD Author. This program will not let anything pass that is non-DVD compliant, and when I tried to import the stream, it said the bitrate was too high, so I opened it in Womble, and sure enough, it reported a bitrate of 10 mb/sec. I didn't believe this because the size of the mpeg would be considerably bigger if it was, so I opened it in Power DVD and that reports the bit rate that never gets above 5 mb/sec.
I'm at a loss to understand this.. Anyone any ideas what might be causing this? My only option as I see it is re-encode the the entire file-and the programme is nearly 2 hours long, so it would take forever!!!
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 11:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Mpeg2 artifacts at ~high bitrate.
By ronkkrop in forum LinuxReplies: 24Last Post: 13th Apr 2008, 16:06 -
high bitrate h.264 looks like junk???
By RadicalxEdward in forum Video ConversionReplies: 14Last Post: 12th Jan 2008, 21:38
