I dumped a movie from video tape and used Cuttremaran to edit out the commercials (it did a good job). Then, I encoded with TmpGenc 2.5 xx to 352X480 (1/2 DVD) specs. When I went to burn, using TmpGenc DVD Author, I got the following results:
The video sequence header is incorrect.
A video sequence header is necessary for every GOP in a standard DVD
and:
You can also set the "sequence header output interval" manually, in "MPEG Settings", "GOP structure".
How can I get this to work as it says no headers. I thought they would be placed in as I encoded? I set the sequence header interval to 18, but still no soap!
So the format which you are trying to burn with TDA is mpg ?
What i think his problem is is that he has converted in tmpgenc and is now trying to burn in TDA without creating dvd structured files - hence the problem
I see,i reread that and saw he was trying to burn the encoded files instead of authoring,no wonder for the error.
That caused your problem,thought you were trying to fix a mpeg file.That setting only gets screwed up if you load up any file and not use any template to start with.
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 11:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 16:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43
