Hi,
well i have just re install windows xp in my pc as i had before i formated my hdd, i have a lifeview 2000 video capt. card installed, i use inter video win dvr as the main capt. sofw. as i always have. After this new re installation of xp i tryied to capt some old vhs videos as i have done b4 but this time when i open win dvr i can see the video running but i have not sound at all, my pc have the sounds working fine, i can run any video and it has the sounds, i checked the program settings, winxp sounds settings, i even ran win dvr from win Me wich i have installed too in my pc i have video and sound fine but it doesn't work with XP, why? anyone have any idea? i have tried everything i could but i just can't get any soundi don't know what else to do.
I hope i haven't missed any info, thank you very much.
Do you have the audio cable plugged in from your capture card to the line in port of your sound card?
@lancerx
I know you probably already did, but double check in the winxp sound settings, under "recording" and make sure the line-in is selected, not muted, and that the slider is not all the way down.
mastersmurfiejust a thought
mastersmurfie
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01 -
Need help geeting TV Guide to work with my Toshiba RD-XS34SU
By ITIL2 in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 06:27
