Well lets jump raight in
The problem im having is this: When i try to add my .mpeg's in tmpgencdvd it says the framerate is 23.976 which isnt good enough for a dvd so i was wondering if its possible to make it recognize the framerate or if i could just change it somehow anyinfo would be great and if anyone out there needs more info about the files just reply and ill get it on here asap
Thanks all Peace
The framerate has to be 29.97 fps but you can use pulldown.exe with gui and do 2:3 pulldown so it plays at 29.97.No re-encoding needed unless its mpeg1.Has to be mpeg2.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57 -
Wrong resolution/framerate on mkv converted to bluray with TsMuxer
By tomamitai in forum Video ConversionReplies: 2Last Post: 30th Mar 2009, 03:13 -
i need a framerate converter
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2008, 21:44 -
Framerate Conversion
By rackball in forum Video ConversionReplies: 10Last Post: 11th Aug 2008, 04:04
