  1. Hello all:
    I recently captured some low res material using the PicVideo codec (18 or 19 quality level). I plugged it in to TMPGEnc thinking that it would quickly convert to MPEG2 but it is taking about 4 times as long as a Huffy capture, all other things being equal. Is this normal? Any way to speed it up?
    Thanks-
    Apr 2002
    The State of Frustration
    That's about right. You may want to do a video conversion only to speed things up a bit, or if quality is not that important, try Msin Concept.
    Hello.
  3. TMPGEnc is slow!!
    I use WinAvi, like 20 times faster and good quality, easy to use!!
    http://www.winavi.com/video-converter.htm
    You will like it!!
