I am using an ATI AIW 9000 with ATI MMC 9.1 to capture CAV LaserDiscs.
Does anybody know about capturing I-Frames only?
Results 1 to 19 of 19
it is the same basicly as capturing to mjpeg ....
you need a high bit rate to do this ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
There's no reason for I-frame only.
Not unless you're expecting to edit. Like BJ_M said, that's essentially MJPEG.Want my help? Ask here! (not via PM!)
even the sony IMX mpeg is not all I frame and it IS for editing ...
it is IPPP"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks for the input guys...I guess my real question is what is the relationship between I-P-B frames and overall video quality? Let's say you're doing 704X480 at 6-8mbps. I was assuming that basically the more I Frames the better? Or for example, giving everything else equal, would there be a video quality difference between 1-4-2 and 1-2-2 (I-P-B)? That is what I'm really curious about...
Quality is not dictates by this as much as it is by bitrate allocation.Originally Posted by http://www.digitalfaq.com/capture/avivsmpeg.htm
Adequate bitrate on an I-P-B encode should be fine for you.Want my help? Ask here! (not via PM!)
To elaborate on lordsmurfs post, at a low bitrate I-frame only would have a detrimental effect, and at a high rate, there would be very little difference, likely.
I-frames contain the complete picture information. P-frames contain only information that differs from the frame before it. B-frames contain only information that differs from the frame before it and is not in the frame following it.
At a low bitrate, there is simply not enough room to store a series of high-quality I-frames -- but when P and B frames are used, less bits are necessary for those and be spent on the I-frames instead for better picture quality. -
dependsOriginally Posted by DivadX"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I'm actually VERY curious where BJ_M is going with "depends" (come on big fella, I'm all ears!)
Anyway, my experience shows that this depends largely on the software/hardware, in terms of IPB radius and the quality it gives out.Want my help? Ask here! (not via PM!)
Yes...maybe it depends on the price of tea in china...or if it is a full moon...
Guess I'm not being very clear...
"Giving everything equal" means same hardware, same software, same source, same resolution, same bitrate, etc...
Then if you captured it once at 1-4-2 and again at 1-2-2 would there be any video quality difference? -
It depends. Sometimes worse, sometime better. Lots of factors.
Depends on the bitrate, on the video, on the capability of the encoder...Originally Posted by DivadX
Shorter the GOP, more bitrate you need (because you use more I pictures in place of P or B). If spare bitrate you have, you may benefit from shortening the GOP.
Also, less complex the video (in terms of MPEG compression), less difference it will make (hence I said "may benefit").
But all this pretty much depends on the encoder and how it chooses to allocate the bitrate among the pictures and how it chooses to encode the P and B pictures' macroblocks.
So, we're back to what BJ_M and lordsmurf said, depends... Try and see. -
even if a lot of high freq. content (trees , grass, smoke , water, brightly lite outdoors scenes) vs. lower freq content (animation, space , static objects , black, indoors low lighting) can change results ....
petar has a good answer"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Isn't DV-format video (like used by MiniDV camcorders and output from ADVC-100) basically I-frame only?
yes - but it is not using jpeg or lzw type compression .
OK I did some experiments and thought I would share the results:
I captured Side 1 of SW Definitive Collection CAV LaserDisc which contains a really good mix of lettering, space, action, lo-motion, and bright scenes using...
*ATI AIW 9000
*ATI MMC 9.1
*704X480
*6-8mbps
*LPCM audio
I did this 3 times with open GOP's 1-4-2, 1-2-2, and 1-1-1 (I-P-B).
Result #1 (1-4-2)
637MB file size, peak bit rate 8.3, avg bit rate 3.2
Result #2 (1-2-2)
667MB file size, peak bit rate 8.6, avg bit rate 3.3
Result #3 (1-1-1)
781MB file size, peak bit rate 8.2, avg bit rate 3.9
After authoring and watching on a TV they all look pretty good, but IMHO the "shorter" the GOP the better the video quality in my scenario. -
With active capturing, I find too many "P" frames can make quality degrade.
It's amazing how confusing this all can be.
I-frames are VERY expensive on the bandwidth (i.e., bitrate). The main reason that P and B frames are used is to limit the data to effectively get "free bits". An mpeg file with all I-frames would be a tremendous bitrate hog.
If you want to do editing, then you don't want mpeg to start with. Use something else and then convert to mpeg later (if that's what you need for your final output).
Analog capture with Studio Pinnacle 15HD, Dropped frames?
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 31st Dec 2011, 16:00 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Pleas Help with intensity pro capture dropped frames issue
By jub2k3 in forum Capturing and VCRReplies: 14Last Post: 18th Jun 2010, 13:38 -
How can I automatically capture still frames of a video?
By SamScaff in forum Capturing and VCRReplies: 1Last Post: 13th Sep 2007, 20:28 -
Jerky capture with duplicated frames
By putte67 in forum Capturing and VCRReplies: 3Last Post: 20th Jun 2007, 18:56
