I am converting an Xvid AVI to DVD and the video comes out perfect but there is no audio. According to GSpot the audio is:
0x0055(MP3) ID'd as MPEG-1 Layer 3
Bitrate:139 kb/s (69/ch, stereo) VBR
Fs:48000 Hz
Is there any way to convert this with audio?
I'm pretty new at this myself, but I will try to give a suggestion. You probably need to extract the audio from the file prior to converting it. I usually use Virtual Dub for this. Try this guide and see if it helps you.
http://www.lancey.info/tutorial/divx2dvd.html
I hope it works for you.If I say or post something stupid, please excuse me because I am a computer dummy. - Kaizen10366 -
Thanks for the link. For some reason when I open VirtualDubMod there is no Audio option on the toolbarOriginally Posted by Kaizen10366
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
PCI-Express sound card
By leesider in forum AudioReplies: 6Last Post: 2nd Dec 2008, 02:38 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
Tmpgenc Express rendering real video, result no sound
By pcb in forum Newbie / General discussionsReplies: 0Last Post: 31st May 2008, 15:17
