    Oct 2002
    canada
    Helllo
    I just bought this dvd writer, and i need to know if the burning speeds that i'm getting are legit.
    I just burnt an mp3 dvd, total of 2.5 gigs., on a memorex dvd-r 4 times .
    It took 19 minutes. Does that sound right?
    It took me 90 minutes last night to make a backup of the movie the matrix., on dvd+rw media.
    I use nero and clone dvd.
  2. Member HAMP's Avatar
    Jan 2004
    Is that only the burn time? or are you counting the compress time as well? as part of the 90 minutes?
    Oct 2002
    canada
    Problem solved
    THe burner was defective.I got another one and now it takes me only 55 minutes to do it alll
  4. Member HAMP's Avatar
    Jan 2004
    I have a Plex 712A and it takes me 22 minutes to do it all.
  5. Banned
    May 2003
    Massachusetts
    55 minutes sounds fine, so long as you're including the time to rip/compress in that total.
    If that's just the BURN time, you've still got problems.
    - Gurm
